While creating a sub vi mostly I don't bother about how the front panel looks and also while coding its easy to take the constants from the function palette. What we will do if we need a control in the block diagram.
Method 1: Select a constant and then convert that into a control
Method 2: Go to the front panel and place the control that is required.
Instead of doing these things it would be best to be able to place a Control in the Block diagram (Even the error clusters). This may be implemented by
Right click mouse to launch Function palette --> Place the mouse pointer over the contant --> Press CTRL and Drag the constant to the Block Diagram. Control is created. I was having this in mind for a long time but not able to post. I am not sure whether it has been already posted.
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
