pavanb
LV Robotics needs Series Elastic Actuator control algorithms, examples for legged robots
Status: Declined
Checkout
NASA JSC Concept M Video, http://www.youtube.com/watch?v=kFPNcWN7QnM
Robonaut in space, http://www.universetoday.com/2010/03/24/iss-to-get-man-cave-complete-with-robot-butler/
http://www.google.com/url?sa=t&source=web&ct=res&cd=1&ved=0CAsQFjAA&url=http%3A%2F%2Fciteseerx.ist.p...
If GM can mass produce the R2 for DoD and in the future for commercial applications the potential is tremendous.
Pavan
3 Comments
RoboticsME
Thanks for the feedback!  Let us know if you have any other suggestions.
-Karl
RoboticsME
Check out this example: http://zone.ni.com/devzone/cda/epd/p/id/3226
This example is also included with CD/Sim and is named: CDEx Flexible Joint.vi
Let me know if that is along the lines of what you are looking for.  I believe it could be easily extended to a series elastic actuator for a humanoid robot/leg.  However, you may have to linearize your model at each timestep.
Darren
Proven Zealot
Status changed to: Declined
