User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I know "quick connect" is a new feature with Labview. Labview would choose to connect the newly added block to an adjacent receiving block automatically. But I am encountering some minor inconvenience when using it, expecially when there are multiple receiving blocks close to each other. This feature is actually making connecting procedure more complicated. As the chance of the newly added block to select the correct block to connect is small, corrections need to be made each time, which made connection even more time-consuming. I would recommend doing something similar to Simulink, where you select the ports you wish to connect while holding down some hotkey (say ctrl or shift) to quickly connect two adjacent blocks.
