I just spent way too much time debugging a really stupid issue (it actually took that long because it was manifested in a specific location and there were some red herrings).
Essentially, I had code like this and I couldn't figure out why it was returning false:
The answer was simple, once I realized the problem was there - I wired the lower value (option 1) to the "upper limit" input, which means the function will forever return false.
I suggest that the "In Range and Coerce" function should function correctly regardless of which input we wire the value into (maybe by including a simple Max & Min call inside it) and that the names of the inputs will be changed accordingly.
Possible problems:
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
