While the LabVIEW Statechart Module has some capability to run in debug mode, if the statechart is broken/unable to run then the information available as to why it can't run or deploy is inadequate.
I have come across the following situations:
- Editing the statechart, it appears OK, but when linked to a 'Run Statechart' function the calling VI is broken. No indication of why.
- Double-clicking a state to edit it results in a 'Cannot load diagram' message. This appears to be memory corruption (completely closing LabVIEW and re-opening it usually fixes it), but the error could be more explanatory, or offer to purge the statechart from memory and reload from disk.
- Many edits to the statechart diagrams/reactions/guards/triggers do not trigger a forced recompilation even though the functionality has changed.
- Deploying a statechart to a Real-Time target can fail (even though the statechart and its calling VIs are unbroken), and when it does the information provided is useless. "statechart.lvsc:Instance72.vi loaded with errors" is a useless message as there is no way to relate 'Instance72.vi' to a particular object on the statechart.
Can we please have more (any!) debugging information.
- Reverse translate 'Instance72.vi' to an object on the statechart.
- Allow us to inspect the intermediate VIs of statechart compilation (i.e. allow us to open 'Instance72.vi' to see what code has been generated).
- Allow us to export the statechart as a standard VI structure for editing/running - i.e. use the statechart module as a design/documentation/template generation tool.
- Fix the inconsistency between an unbroken statechart and a broken Run function.
- Make sure functionality changes require recompilation.
- Improve Real-Time deployment to give more information than simply 'loaded with errors'.
Richard.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
