User | Kudos |
18 | |
17 | |
10 | |
5 | |
3 |
I am Facing the problem when VIs Having the visual Images in Front panel for Operator Instruction screens.
( such a connecting the Cables, Visual Inspection of Components etc)
If you use these type of visual images the total Executable size increasing huge (my case 150MB beacuse of many products and many Images,images are copies from the *.Jpeg or .png Images.if the LabVIEW can find these image copied on the front panel and able to compress . we can reduce the EXE file size almost 30% of the total size and also taking more time to build and compile
NI have to find is there any technique(now a days many image compression models are avilable) , first compile the code and later add images to front panel once compile.
Declined, several viable alternatives are listed in the comments section of this idea post.
