About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Hide This VI label as default
The label should be hidden as standard on This VI referrence as it gives no extra information, it only clutters the block diagram.
/Y
5 Comments
Knight of NI Knight of NI
Knight of NI
Agreed.  But in your example, you do not even need the reference.  A property/invoke node of class VI will default to using the This VI reference if not wired.
Trusted Enthusiast
Trusted Enthusiast
The default of a property node is App, atleast on 2011 that i'm on today. Smiley Happy
Knight of NI
Yes, but if you change the class type to VI it will use the This VI.
Right Click, Select Class->VI Server->VI->VI
Trusted Enthusiast
Trusted Enthusiast
Ah, right. Good point. It does not change my suggestion though. Smiley Happy
Member SABARI_SARAVANAN_M
Constant VI server reference label to be default in LabVIEW. You can't change it from
==> options ==> tools ==> block diagram. If you wants to disable that label go to
==> visible items ==> label.
