3D graphs should be hardware accelerated. Right now they are terribly slow. But if you Right Click -> Render Window, it is smooth and makes a WORLD of difference.
Right now there exist workarounds - in some applications, I'm programmatically calling the render window. But then I lose out on the projection pallete and color ramp - so it would be best to at least provide the option for users who have suitable hardware. I see no reason why this doesn't already exist.
The old ActiveX 3d plots don't work on 64bit LabVIEW so that's not a solution.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
