When you have a VI with multiple subVI’s, you often have numerous windows open – maybe not during the development as you finish one subVI, close it, and then return to the main VI. But if you inherit a VI from a coworker and you’re trying to figure out what his code does, or when you’re in the support department as I, it would be a nice feature to group all your opened windows.
See my illustrations: The first one shows a mainVI where I have opened two subVI’s making it a total of 6 windows. The next one shows the same example but this time grouped into tabs. Of course one should still be able to quickly separate the tabs into windows.
One other feature could be to make an option named “Lock front panel to block diagram”, meaning that if you click a tab on the front panel, the tab on the block diagram automatically switch to the respective block diagram and vice versa. Again, this option should be easy to disable.
This idea differs from Jack's idea “LabVIEW IDE Overhaul”, because it does not merge the front panel and block diagram into one window – that part is still separated in this idea. Also, Jack’s IDE-change was presented to users in LabVIEW 8.0 Beta, which is about 7 years ago! I personally think that the LabVIEW users are ready to experience LabVIEW with tabs. I don’t think it’s a duplicate of Jack’s idea, but even if you guys think it is, my opinion is that it is time to give it one more try…?
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
