Get contents of all XML Node Types:
As a beginner at XML parsing, it would be great if LabVIEW had a VI (like Get Node Text Content) but for every node type (it would get the contents, whatever they may be).
All node types stated here:
http://www.w3schools.com/dom/dom_nodetype.asp
are possible and may require a different set of property/invoke nodes (some have children, some don't, some have values, some don't... and so on).
Inputs: Node handle
Outputs: Raw node contents (whatever XML is contained within the tags of the Node handle), Value (where applicable), Name (where applicable)
Write general string to XML node type:
It would also be great if there was a VI (or set of VI's) that could take an input (as a string) convert it to the w3 conformant XML. It's important to use the w3 definition, rather than LabVIEW XML for external compatibility.
Inputs: Node handle, Node Type
Outputs: XML string of Node Type
CLA, CTA
Not my tempo... AGAIN!
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
