This method is of very limited use (probably useless) in practical applications.
The general use-case is for more than one plot to be displayed on the same graph. With the current implementation, if plots overlap (or cross), it is impossible to determine what plot the given coordinates are on.
This method should return an array of plots.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
