MGiacomet
Get Plot At Position Method should output a vector of plots
Status: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
This method is of very limited use (probably useless) in practical applications.
The general use-case is for more than one plot to be displayed on the same graph. With the current implementation, if plots overlap (or cross), it is impossible to determine what plot the given coordinates are on.
This method should return an array of plots.
2 Comments
X.
Trusted Enthusiast
Trusted Enthusiast
Keep in mind that this method will crash LV in some cases, so you probably should stay away from it and write something similar to what I pointed at in the previous thread. This being said, you have a point and I may look into updating my own tools to do just that.
Darren
Proven Zealot
Status changed to: Declined
