Some people will prefer if the front panel is designed by a graphic artist. You don't want the graphic artist to touch (or even see) the source code or to change controls or indicators in the front panel to ones that will make the VI inoperable (replacing a numeric indicator with a string indicator, for example.)
It will be nice to have a "Front Panel edit mode" where you can only edit the cosmetics of the front panel: move controls and indicators, resize, change colors, etc., test the "Scaling Front Panel Objects" feature (if used), add clipart, etc., with constraints such as only replacing with the same datatype (unable to replace a numeric indicator with a string indicator), unable to change a control into an indicator and viceversa, unable to delete controls or indicators (but perhaps you can add and even link to an existing control or indicator.)
Regards;
Enrique
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
