Yusuke.T
Formula node forbid to run VI when undefined variable is used
Status: New
On all LabVIEW version, we can use Formula node to evaluate mathematical formulas.
We can define input and output variable freely and calculate using some variety of formula.
But when we use undefined variable as output, can execute VIs with no errors.
We think it is a problem because when programmer makes a typo, they cannot notice the mistake.
When undefined variable is used as output variable, LabVIEW should forbid to run VI.
1 Comment
X.
Trusted Enthusiast
Trusted Enthusiast
I think you are going to get the same (or similar) answers than to my suggestion(s) to make VI outputs potentially "required" and the same for some functions (built-in VIs):
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-required-outputs-in-VIs/idc-p/3157058
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/quot-Function-terminal-not-connected-quot-detection-pl...
In general, I agree with you, there is a potential for problems. Not really for the reason you are mentioning, because a typo will break the VI (unless you have two output variables with very similar names - unlike in your example - such as y and y0). But it could make for some frustrating debugging session.
