User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
When I try to pull a BIGINT value from a SQL database with the Database Toolkit the variant that is returned apparently does not have the value from the database. I say apparently because if you convert that variant to a string you get the data.
My issue is that when the data is in variant format it looks like the data is gone. I think that the value should be displayed to avoid errorneous thinking that there is a problem with my SQL query. This is very misleading and I think the variant value and the string values should match. Otherwise, it looks like there is an issue with my SQL statement.
Here is a screen shot of my code in which this occurs:
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
