The "Coerce dots" are handled by LabVIEW as Visual warnings ... but a bad type coercion could have very bad issues !
It should be nice to be able to find all "Coerce dots" in all the VI's of a project, in order to check if they are critical or not.
[admin edit] This functionality is currently available with the VI Analyzer Toolkit (included with a LabVIEW Professional license or available for separate purchase). Specifically, you can run the Block Diagram > Performance > Coercion Dots test with the 'Block Diagram' option turned off, and the 'Single Wire' option turned on with a 'Maximum Number' of 0:
If you run the test with this configuration, it will return a failure for every coercion dot in the analyzed code.
Note: The idea will remain open, but we're mentioning the workaround here for the benefit of users who need this functionality today and find this Idea Exchange post via search.
Manu.net
