I would like to suggest that NI add some needed functionality to the FTP VI's that it ships with. As you can see in this thread: http://forums.ni.com/t5/LabVIEW/Access-FTP-with-whitespaces-in-dir-names/m-p/3097215#M886371 the FTP LIST command does not work well for some FTP servers when the directory being listed has spaces in its name. The FTP MLSD command does work in this case, but there are other servers which don't support MLSD. My post on the above thread implements a fairly crude mechanism for using whichever command does work. But more importantly, the MLSD isn't even included in the NI FTP library. It would be great if the NI FTP VIs worked over a broader range of FTP servers.
