That's a matter of opinion. I happen to disagree. I find most math notation fairly distasteful to try to read. I mean, I have the skill, and I *can* do it for all sorts of arcane things, but even that basic notation there is less clear to me than the graphical notation of values going to operators. As I said, opinions vary. There are people who like writing whole applications in text. I prefer not to whenever possible.
even though a dummy input is required (0 here, but obviously anything would work just fine), compared to that:
but it is true that my opinion is of little value, since I have to deal with this kind of formula on a regular basis...
I wonder what the Help for this node has in mind when it refers to "complicated" expressions:
Irony aside, regarding your proposal, you already have something quite close with this:
The Expression Node in fact supports (almost) all operators supported in the Formula Node, so there is quite some choice.
The problem you would have is that the "=" operator is an assignment operator in the syntax of the Formula/Expression Nodes, but isn't supported in the Expression Node (because it only supports one single variable). Forcing it to have a different meaning in the Expression Node would be confusing.
This being settled, how would you tell the node that you want a Boolean output rather than the natural numeric one? Some contextual menu option? I would argue that this is more pain than I would be willing to deal with.
Moreover, the syntax above also works with arrays:
and clusters as well:
How would your new proposal handle this? Output a single value? An array, a cluster?
Strings? Seriously? It is my understanding that using strings is not recommended in LabVIEW...
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
