User | Kudos |
21 | |
18 | |
11 | |
5 | |
3 |
This should work!! I know there are workarounds and I have used them but it would be much easier.
On Windows, you can define environment variables that auto expand to known directories. There are some variables that are already defined by the system. For example, %TEMP% automatically expands to c:\Users\<username>\AppData\Local\Temp OR WHEREVER THE USER MOVED TEMP DURING INSTALLATION. That's the important part .That makes it possible to write %TEMP%\abc as a symbolic path that works regardless of how the system gets reconfigured.
Users can define their own environment variables, and those get expanded when used in a path in the command line or Windows Explorer (the text entry region at the top of an Explorer window). On Linux and Mac, it is the equivalent of using $VARIABLENAME/abc, where VARIABLENAME is some user-chosen name.
[admin edit] Added background information on environment variables, and updated title to use the word "Environment" instead of "Environmental".
