Writing good code typically involves spending a lot of time coding up error handling cases.
Dropping error cases around enumerated or string controlled cases is a common structure task.
This takes up quite a bit of diagram space and coding time when integrated over the entire job.
If an enumerated or string controlled case structure could have an optional terminal dedicated for the error data type only, this structure could be more efficient to code.
A typical implementation looks like this:
My proposed structure would look like this:
Cheers.
Ray M.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Multiple-Case-Selectors/idi-p/1301780
