User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
After we have gotten several different new tunnel modes, it takes quite a lot of context menu exercise to change tunnel mode on structures:
I propose a shortcut where we can click directly on the tunnel to toggle between valid modes:
I say valid modes as not all modes are valid for all tunnel data types, for instance the "Concatenating" mode isn't allowed for scalars, but is still selectable in the context menu resulting in a broken scalar wire leading to the concatenating tunnel - the toggle should perhaps skip such an invalid setting? Or maybe not, in case you're preparing to change data type and just want to toggle the tunnel first, I don't know.
Tunnels on different structures have different modes. On case and event structures the modes you could toggle between would be 'Use Default If Unwired' on/off for instance.
Am I the only one feeling there's a long way into the tunnel mode menu now?
Cheers,
Steen
