At the moment the only way (I know) to fill a picture ring with pictures is to copy a picture item to clipboard and paste it into the ring. There is no way to programmatically fill the picture ring and afaik this is not planned to be implemented because the ring has to be recompiled and so there is no way at runtime (maybe with scripting?).
To simplify this I'm thinking of a way to convert a picture ring into an array of "2D Picture" items and back. Maybe over right click the ring and select "Convert to picture array" and then same way back by right clicking the picture array and selecting "Convert to picture ring".
The picture array can be filled and handled programmatically and with some programming you can create a simple manager to insert, swap, edit and ... your images, show them in a picture array, copy the picture array data in run-time, paste in frontpanel in edit mode and "Convert to picture ring". Done, easy and simple.
