User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
I suppose this is a grey area between feature and CAR, but it is certainly a long-standing aspect of the LabVIEW editor that vexes me on a daily basis that could be improved.
The issue is that if you are dragging to select objects on the block diagram or front panel and you accidentally move the mouse cursor to the edge of the window, LabVIEW starts scrolling insanely fast in the direction of the mouse. By the time you've figured out what's happening and released the mouse, you're often 4-5 screen lenghts away the actual content of the diagram, and you must now manually scroll back to the main area. To make things worse, you're not really sure where the origin is anymore, so it takes a little blind searching to find the screen contents again. In addition, you're likely left with a selection that is not what you intended, meaning you have to start over (more carefully) from scratch.
I really don't see any reason to scroll the panel so terribly fast. At all. A slow, steady scroll, in my opinion, would always be preferable, since the fast scroll leaves the user no real control at all over what's being selected. If anyone really wants a chaotic super-fast scrolling operation to be preserved, I would perhaps accept a shift-drag option to enable this.
