My work-around solution was to resize the column width to "0". You can make a loop that takes say the first 10 columns and minimze the width. Once you populate the column again, you can restore the width to something more normal. This solution is not perfect, but better than nothing.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
