Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
Ctrl+Find in labview doesn’t find text inside FPGA read write nodes. So once needs to select that node and do a Ctrl+F and find them all vs. only a certain text inside them.
I have this exact problem. I am working on someone else's code where they used FPGA Read/Write control everywhere in the diagram. Being able to search on strings would go along way to helping untagle the spaghetti.
The same problem exists in the FPGA with FIFO, register and memory nodes. You can find all the nodes, but you can't search for all the nodes for a given FIFO. If you have a program where registers have been used like globals, it can be difficult to understand. Search would help.
