GuessWho
Create Constant - Label causes resize of structure when plenty of whitespace is available
Status: New
When you create a constant on the diagram from an object with a name, often the new constant's label runs into the enveloping structure's border, causing the structure to resize.  This process is quite dumb, as even if there is lots of room around the constant, LabVIEW insists on forcing a resize due to the collision.  Since the space is there, surely the routine could recognize that and only force a resize if there is not enough space.
in the example, the control was against the LHS of the loop; after creating the constant, I moved it down for vertical clearance, then made the label visible.  The label forced the loop resize to the left, ignoring the space to the right.
11 Comments
Manzolli
Maybe this idea can be spiced up with a keyboard control to set the text's justification:
[Shift+Left] = Left Justify
[Shift+Down] = Center Justify
[Shift+Right] = Right Justify
These keys shortcuts are already used to move objects faster. I believe that the environment can handle both cases checking if a text is being edited. If not, just use another key combination.
With these two working together most of simple cases are covered. Other cases should be solved by the user.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
