Senthil_Prakash
Copy and Paste elements in Cluster
Status: New
When we try to copy and paste a element in the cluster constant its not replacing its added as the new element.but it working well in the control and indicator
The figure explains the problem
Senthil Prakash S
Certified LabVIEW Associate Developer
8 Comments
Manzolli
Looks like a problem to be fixed, not a suggestion of a new feature.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
Darren
Proven Zealot
Paste-Replace is currently only a front panel feature. The fact that it hasn't been implemented on the block diagram is more of a feature request than a bug. I would say this idea post is suggesting that paste-replace work on the block diagram as well. Which I agree with.
ToeCutter
Kudos- this has given me a lot of headache recently. BD should behave like FP.
Intaris
Proven Zealot
Kudoed the idea of paste-replace working the same on the BD as it does on the FP.
Senthil_Prakash
Whether this idea will be fixed in the latest version of LabVIEW
Senthil Prakash S
Senthil_Prakash
Most of us faced this issue please give more kudos so that it will be done soonSmiley Happy
Senthil Prakash S
AristosQueue (NI)
NI Employee (retired)
So what you're saying is that you have a cluster that isn't a typedef and you're having trouble using it. Sounds like the solution to me is to make it a typedef... then you'd be editing its type on the front panel! 🙂
Ok, joking aside... I agree constants and controls should function the same. This isn't my area of the code so I don't know how to address this myself, but I like the idea.
Even so... make it a typedef. Always. 🙂
X.
Trusted Enthusiast
Trusted Enthusiast
@AQ: sure, but when it is easier to create the typedef on the block diagram (because that's where the data structure exists initially)? I was about to submit the same idea for that specific case (on my way to create a typedef, but the initial structure was easier to create on the block diagram - I had to create a few controls to go around this limitation).
