About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Converting strings (control/indicator <> constant) should retain display format
We can right-click a string object and change the state (control, indicator, constant, array, element) by right-clicking. Unfortunately, the current behavior is (partially) inconsistent in the way the display format (normal, /-codes, pass, hex) is handled. Here are some results (list is incomplete), the symbol <> means in either direction.
Control<>indicator: The display format is retained
Array<>array constant: The display format is reset to "normal". *(Also see below)
Control|indicator<>constant: The display format is reset to "normal".
(*note that if I drop a string constant into an empty array container, the format and element size is retained. Converting to array using right-click should do the same!)
Whenever a conversion involves a diagram constant, the current display format is lost. I think it should be retained!
1 Comment
Trusted Enthusiast
Trusted Enthusiast
I'd add: when creating an array from an element, create it with a single element identical to the starting one...
BTW, the Change to Array feature is a LabVIEW Shortcut Menu Plugin, not a native function, so you could in principle modify it to do what you are asking (Check Execute Change Constant to Attay of Elements.vi in C:\Program Files\National Instruments\LabVIEW 2016\resource\plugins\PopupMenus\edit time panel and diagram\Change Constant To Array Or Element.llb
