when you want to create a constant cluster using the context menu item "Create constant", the new constant is created by default in "Big", not iconified.
This can cause problem if the constant creation takes place in a structure ... because the structure is then automatically resized.
It should be nice to use the new LV2010 feature which allows to transform a cluster in an iconified way.
