Currently when you look in a project file the context help only changes when you move the mouse over a new item.
It does not change if you select an item in the list and then use the up and down cursor keys to move to a different item.
IDEA: Update the context help when a new item in a project file is selected using the cursor keys.
Filed as a bug report (see previous comment)
