SteveP
Conditional terminal for individual frames of sequence structures
Status: Declined
State Machines are a lot more robust architectures than this functionality in a Flat Sequence Structure.
A conditional terminal for each frame of a sequence structure would allow one to exit the sequnce at any frame.  This could be useful in case something occured in one frame that meant the remaining frames should not be executed.  Easier than having to use case statements in the later frames.
4 Comments
RavensFan
Knight of NI
I don't think such a thing is needed.  If you've spent any length of time in the forums, you know sequence structures are frowned upon in most cases and should be replaced with a state machine that would allow you to exit the structure at any given iteration of the state machine loop.
crelf
Trusted Enthusiast
Sounds like you're after a state machine...
Copyright © 2004-2023 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 2.5 License.
JackDunaway
Trusted Enthusiast
G-Money
NI Employee (retired)
Status changed to: Declined
