When building strings from many sources using the "concatenate strings" vi it very quickly becomes confusing and unreadable. The vi is very small, the inputs are very small, the wires are very close together and require many crossings. It would be very useful if right click on this vi would bring up an "expanded size" option that would double the size of the input terminals. Another right-click option that would be useful would be to rotate the vi 90 degrees so that the inputs are on the top. This way you could arrange your inputs from left to right in the order that you with them to be concatenated, and then wire them to the vi without needing to cross wires.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
