wsaall
Concatenate 1D array in For Loop output tunnel
Status: Already Implemented
Available in LabVIEW 2012 and later
Smiley Wink Only single click to concatinate 1D array out from For Loop:
 Usually we can make it like below Smiley Sad.
But which easier, faster and most elegant Smiley Happy.
12 Comments
Gharb
I hope if it exist
Aiman2020
I like it.
tst
Knight of NI Knight of NI
Knight of NI
You're right, it's a great idea, and luckily it already exists in LV 2012 - you can right click the tunnel and select concatenating as one of the tunnel types.
Also, getting all your friends to comment on it is not necessarily what's going to get people to vote for it. Just let the idea stand on its own.
___________________
Try to take over the world!
wsaall
I am so happy for that, so I will not wait more time just updating Smiley Happy
Thanks Permalink.
jcarmody
Trusted Enthusiast
What are those hens saying to the rooster?
Jim
Gharb
" The leadership is not just giving command " written in arabic
jcarmody
Trusted Enthusiast
Thank you.  I knew that someone in our community would provide the answer.
Jim
Intaris
Proven Zealot
That guy "Permalink" sure is posting a lot..... Smiley Tongue
Norbert_B
Proven Zealot
@wsaall wrote:
[..]But which easier, faster and most elegant Smiley Happy.
Is that really a suggestion (see tst's comment if it is) or is it a question on performance? If it is a performance question, you posted this to the wrong forum since this is the idea exchange for new feature suggestions for LabVIEW.
But to give an answer anyways: You should use the feature of LV 2012 to concatenate arrays (first option) rather than building a new array like seen in your second image.
Norbert
Norbert
Expert: Geometry
dthor
I *think* what wsaall is trying to suggest is:
Currently (2012) the output tunnel of a loop can be changed by right-clicking on the tunnel, selecting Output Type, and then selecting Last Value, Concatenating, or Indexing. I believe the proposed Idea is to remove the Output Type step.
But hey, I could be wrong Smiley Happy
