User | Kudos |
4 | |
2 | |
2 | |
1 | |
1 |
I was looking at Altenbachs suggestion about adding the ability to 'Make Current Controls values default' and had a thought. What about resetting the controls to their 'factory' state defaults. The 'Reinitialize Values to Default' menu selection will set the controls to the current default, which may not be the original default value due to the use of the 'Make Current Values Default' option. What I am suggesting is a menu item 'Clear Changed Default Values' which will remove any changed default value and reset the control/indicator to its 'factory' setting.
A quick example where this might be nice, is if I have several arrays that I have populated and set to default for debugging purposes, when I'm done debugging it would be nice to be able to go to the edit menu to clear all of the arrays rather than having to select each one, clear its contents, and then saving the cleared array as the new 'default' value.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
