User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
When tabbing between strings, you can type in each box.
When using Rings and Enums, you can select items by typing after the control has been clicked on; for example, if "Lead" is in the list, you can click on the Ring/Enum and type "L" and the control highlights the first element with "L" in it. You can then hit "enter" to choose that element in the list.
It would make much more sense from a user's standpoint if they could tab to a Ring/Enum, and start typing to choose an element.
I propose that when a user tabs to a Ring/Enum control, that if the user starts typing, that the Ring/Enum selects an element similar to if the user had clicked on the control.
