There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
Check out the suggestion in the linked idea above...if you're in LabVIEW 2012 or later, you can use the Ctrl-Space, Ctrl-Shift-R shortcut in Quick Drop to remove unused inputs from the Build Array function.
