If you try to "set variant attribute" and inadvertently wire in a blank string, this wipes out all other attributes from a list of attributes inside a variant. An error should be returned, but destroying the rest of the list of attributes should not occur.
I agree with you that this doesn't seem to make sense from an API perspective and that this could be implemented with a separate primitive, but I'm not sure how easy it will be to change it, because there might be some code out there which relies on this.
I do not have LV here to test, but I have posted enough examples to the Forums where I specifically rely on a blank name to throw an error to stop a While Loop and this does not empty the attribute list. The behavior you describe is similar to wiring a blank name to Delete Attribute.
If this is new/different behavior in LV11 then this is a bug of the highest order. Please confirrm version and post a snippet demonstrating this behavior.
I must be mis-remembering. You're absolutely right, the error that gets thrown out when you wire in a blank string must have screwed me in some larger architecture designs in the past.
Thanks for requesting the snippet of code, it allowed me to go back and verify this behavior.
