User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
When you have a lot of cases (or events) in your case (or event) structure it can be tedious to go back and forth between them (yes, Ctrl + Mouse wheel works great but can be hit and miss to get to the right one that is many cases away). Often times I am in one case, I need to grab/do/look at something in another case and then return to the case I am working on. It would be nice to have a Back and Forward button (similar to a web browser) so after I can quickly jump back to where I was. The only way to do it now is to click on the case titles, scroll up/down (which can be very tedious if you have enough cases that it goes off-screen) to switch between.
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
