About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Top Kudoed Authors
Automatic Alignment Helpers for Front Panel Controls
This goes a bit with Christian's suggestion to separate edit time and run time front panel sizes.
While I do appreciate the alignment grid on the front panel I find it insufficient a lot of the times. What I would like to see is some alignment helpers similar to the ones that are provided in the form editor of MS Visual Studio:
  • When you move a control close to another control, it automatically displays a standard distance "helper" that you can snap to.
  • When you move the edge of one control close to the edge (in one dimension) of another control a vertical or horizontal line is drawn from that other control to which you can snap, regardless of whether it happens to sit on a grid line or not.
  • When you move a control close to the edge of the front panel a standard distance "helper" is displayed that you can snap to.
All of these features should be available for a move as well as for a resize of the controls.
You can find screen shots of what I am talking about here and here.
2 Comments
Active Participant James_McN
Surprused this hasn't seen more activity. A few tools like this could make front panel development a little more intuitive and 21st century.
Trusted Enthusiast Trusted Enthusiast
Trusted Enthusiast
This would be cool if we could define specific "snap-to" lines for UI placement instead of relying on a global grid.
