Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
It would be nice when Folder Auto-populating will populate VIs to LV Class (.lvclass) and to LV library (.lvlib).
When we use Folder Auto-populating in projects then project hierarchy match disk hierarchy. It would be great when class and lvlibrary hierarchy match too.
VIs need to be modified to be added to or removed from a class or library. Your suggestion requires opening, changing, and (potentially) saving VIs when they're moved into an auto-populated folder. When removing the file from the folder, LabVIEW would have no way of modifying the VI to say that it's not in the class or library anymore.
