99% of the time when I use a Diagram Disable Structure, I am disabling code with an error cluster wired through. I don't want to lose the errors coming in, just the single operation, so I manually wire the error cluster through the empty case each time.
I've talked to others in the past about this and it would be nice for LabVIEW to be all-knowing and wire all datatypes through that match, but that would definitely lead to conflicts and mistakes. Error clusters, on the other hand, are simple are nearly always a single wire in and out.
Simply auto-wiring the error cluster input to the output would make the debugging process much easier.
Code with disabled operation:
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
