User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
While replacing the Property nodes with Invoke node, Call by Reference, Start Asynchronous call and Wait on Asynchronus call, the primitives are shifting the origin disturbing the wires. So a cleanup is reaquired all the time whenever the items are replaced. It would be very helpful and infact time saving if this is corrected.
Place a Property Node in BD with the Error in and Out connected
Replace the Porperty Node with an Invoke Node
Repeat the same with other primitives
The same behaviour is not found when the Call by Reference, Start Asynchronous call and Wait on Asynchronus call primitives are replaced with one another.
Issue fixed with Quick Drop Replace in LabVIEW 2015 and later. We have no further plans to address the issue with right-click Replace.
