User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
Append True/False String is a function in LV, and it allows you to append one of the two input strings to the initial string based on a boolean input. I use it to append pass/fail to the initial string.
I think this function should also allow us to select a couple of standard true/false string without needing a true/false string input. I should be able to right click on the node and select pass/fail, true/false, yes/no, go/no go, etc. By doing this, we can make our code even cleaner. When you select these standard true/false string, the appearance of the icon should also change in order to reflect what standard true/false input is selected.
Yik
