User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
If I have a case statement with 40 cases and they all provide a value to an output tunnel, then when I wire one bad wire to that tunnel in one case, all 40 wires to that tunnel go bad. If I accidently ctl-b the bad wires, then I have to re-wire 40 things.
I would like a right-click option on a tunnel to lock the datatype. If I have locked the tunnel to the correct type, then when I wire a bad type to it, only the one wire will go bad, and if I ctl-b the system, I only lose the one bad wire.
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
