dafemec
Allow the configuration portion of DLL nodes to see mangled function names
Status: Declined
Allow the configuration portion of DLL nodes to see mangled function names, such as those generated by many C++ compilers (@Initv, for instance).
3 Comments
GregR
The call library node configuration dialog attempts to remove the name mangling from function names when it shows them in the list of functions. When you select a function from that list, it shows the full mangled name in the prototype example. Are you hitting a case where this is not the behavior? Can you give an example of what it does show?
dafemec
The mangled names, such as @Initv, simply are not displayed, although I can enter them manually and successfully call them.
Darren
Proven Zealot
Status changed to: Declined
