P@Anand
Allow seletcion of multiple VIs in "Select VI" option
Status: New
At present we can select only a single VI on "RightClick>Select VI" option in Block diagram. It would be much helpful if we can select multiple VIs at the same time. Image for reference
Proposed Method
5 Comments
paulmw
You can however click and drag multiple selected VI's from an open explorer window onto the block diagram.
P@Anand
Trusted Enthusiast
I am aware of that. The proposed method enhances the present VI selection option.
altenbach
Knight of NI
In the old days you were even able to drag a VI from the file dialog to the diagram. Sadly this is no longer possible.
(I guess it broke some established UI guidelines ;). I often used that in the distant past)
JÞB
Knight of NI
AHEM
Stop doing that
"Should be" isn't "Is" -Jay
DanyAllard
altenback, you can do it with this key in your LabVIEW.ini file
allowDragDropFromFileDlg=True
Hope that help
LabVIEW ChampionArchitect
