NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Mads
Allow replace of multiple controls in one operation
Status: New
by Active Participant Mads on ‎07-18-2012 03:08 AM
If you want to replace two or more controls with another type of control you should be allowed to just select all of the existing controls and do all the replacements in one operation.
Currently you have to select one control at a time, right-click it, choose replace, locate the new control - then do it all over again with the next control, even though the type of control you want it changed to is the same as for the previous one.
Comments
by Active Participant jcarmody on ‎07-18-2012 06:02 AM
While you're waiting for NI to implement this, you can use a work-around.  Once you've got one control replaced, select it, copy it, then select each of the other controls and paste the copied control (one at a time).  The selected control will be replaced by the control on the clipboard.
by Active Participant Mads on ‎07-18-2012 06:16 AM
That's a bit better than doing the replace, yes. Another option for now is to create a plug-in for the JKI Right-Click Framework.
But it is such a basic task that should be available out of the box I think.
by Trusted Enthusiast ‎07-18-2012 10:34 AM - edited ‎07-18-2012 10:35 AM
For those of you who use Quick Drop, this functionality is available in LabVIEW 2010 and later.  Select the multiple objects, press Ctrl-Space, type the new object name, and press Ctrl-P.  All selected objects will be replaced with the specified object name.  You can do this on the front panel and on the block diagram.
I do agree though that this functionality should be available in the right-click menu for those of you who still use the palettes.
by Active Participant Mads ‎07-19-2012 01:22 AM - edited ‎07-19-2012 01:23 AM
Good tip Darren. I've been a bit slow at adopting those shortcuts. So far I'm only using the remove & rewire shortcut regularly. I did not think of the replace.
That gives me a new idea actually; put the list of shortcuts on display in the main QD window. That way we can see them every time we open the window, and know our options without having to remember them. If that gets too messy; add a keystroke (to keep the mouse out of the equation) that will show them temporarily (using the button and then navigating to the shortcuts tab is too slow) - and/or put it in a dynamically generated (in case it has been customized) tip-strip for the shortcuts-button :smileyhappy:
Latest LabVIEW Idea Exchange Blog Posts
About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Idea Statuses
Top Kudoed Authors
User Kudos Count
131
81
67
65
58
