Grouping objects on the front panel is helpful to avoid inadvertently destroying a UI's layout.
Unfortunately it comes at a cost: if you want to access block diagram counterparts of any of the objects in that group, you have to first ungroup them, select the object of interest, right-click and select what you are looking for, go there... and hope you won't forget to regroup the objects when you are done.
Surprisingly, you can actually access an individal's object properties and in fact access pretty much any of the right-click contextual menu items BUT the "Find" one. So no "Terminal", "References", "Property Nodes", "Invoke Nodes", Local Variables" access...
Why?
If there is no fundamental reason for this, please consider this as a request.
