Go to Tools >> Options >> Front Panel and turn on "Connector pane terminals default to Required".
This won't help your current problem of fixing all those terminals, but it will keep the problem from happening again in the future. This option makes all new connections EXCEPT error in/out be Required by default.
While you're there, you can turn off "use the numbers 1-9 in the icons of new VIs". Speeds up your icon editing a lot to not have that extra glyph sitting down there, especially when you're working with libraries/classes because then your icon is blank right from the start.
Your idea is a reasonable request. I'm just suggesting this as a better workflow that will help you today.
OK, My workflow to edit an icon usually starts with Ctrl+shift+delete. then grab a template and edit the icon. Where did the "use numbers in icons" option slow me down? To be totally honest, I've never really understood why that option existed except that I need to import MyTemplates (Icons) and MyGlyphs to every version of MyLabVIEW. So, again, How do the numbers slow me down?
Oh, I use them! I still would rather work from MyIcon templates in MyLabVIEW and Ctrl+Shift+Delete is just too easy. (I get to choose the banner color not you guys---- sometimes that can be a nice feature)
SO, Ctrl+Shift+Delete away and get rid of all of those icon layers. Did the number slow me down? What is wrong with "0" anyway? How about using "F?" 1-9 is limited.
And the Project Template Icons? Really, Its a disaster to refactor those Icons in even a simple Plug-N-Play style Instrument Driver project. I get one glyph? It needs a bit of work before Ctrl+Shift+Delete works better.
Um... that means you're getting rid of your own library's icon templates. Why would you want to do that?
Because they suck. Yup, I just out and out said it!
MyCore.vis usually have a look to their icons that resembles either a "While Loop" or have an "<<<" for FBN at the top. The Library Template Banner is a pixel shy in height.
Sometimes Typing a white/Black memonic (Same letters offset +1Y-1X) in the banner helps offset the banner background. The "Shipped For Me" templates just don't stack up to "MyLabVIEW"
