jyang72211
Adding output for obtain queue
Status: Declined
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
Hi all,
To create a queue, the user would need to use obtain queue, which requires a element data type.  Usually, enqueue follows right after obtain queue, and it needs the same data.  A bad looking wire bend is created, since there is no data output on obtain queue.
If obtain queue has a feed through output terminal for data data type, the block diagram look nicer.
Kudos and Accepted as Solution are welcome!
3 Comments
SteveChandler
Trusted Enthusiast
Great idea, especially since there is an empty spot on obtain queue for the data-type passthrough! Another possibility is a boolean input to obtain queue for "Imediately Enqueue Data Type" then you would not even need the enqueue which follows. Maybe both options?
LabVIEW 2012
jyang72211
I like your option.
Darren
Proven Zealot
Status changed to: Declined
